CR tire Size (Diameter)
Old Jan 1, 2008 | 11:38 AM
thorax's Avatar
Default CR tire Size (Diameter)
I was wonder is there a problem with a half inch diameter diffrence? cause the cr uses 215/45/17 and 255/40/17 which has a half inch difrence in diameter. would this cause a problem with abs? can i run those sizes on a ap1? Reason being i ahve volks and i think 225/45/17 will rub since front off set is 50
Old Jan 1, 2008 | 11:45 AM
negcamber's Avatar
That won't throw your ABS off...you can run those sizes on an ap1 with 17" rims with the proper offsets. What are your offsets on the volks?
Old Jan 1, 2008 | 11:53 AM
thorax's Avatar
front is +50 rear is +63. iam reading that tire fitment guide and it says iam basically 3m out. would 225/55 combo be better tahn 215/255
Old Jan 1, 2008 | 12:13 PM
negcamber's Avatar
Unless you have a front swaybar, you would probably be safest with the 215/255.
However, I have the volk CE28n wheels also and run the 225/255 with a big comptech adj front swaybar and have a bit of understeer when not agressive and very neutral when getting on it. And there is no rubbing with the 225 up front and I'm lowered about .5" running 1.75 deg front negative camber.
Old Jan 1, 2008 | 12:21 PM
thorax's Avatar
whats the offset of ur ce? are u certain about it not throwing off the abs? whats the reason to getting bigger fornt sweay bar?
Old Jan 1, 2008 | 04:15 PM
negcamber's Avatar
^^ Offset is the same as your volks...aren't yours CE28n's?
Yes, I'm sure about the ABS...I'm running that tire combo now.
The stiffer front sway bar allows me to increase understeer (it also helps to keep the inside rear tire in contact with the road durning hard cornering). Here is an article that can help explain more:
http://www.turnfast.com/tech_handling/hand..._antiroll.shtml
Old Jan 1, 2008 | 04:25 PM
speedworksracing's Avatar
Just wanted to clear it up. The OP has the tire sizes posted as 215/45 and 255/50, but the accual rear CR tire size is 255/40. Most likely a miss type but I wanted to make sure you dont order the wrong sizes.
Old Jan 1, 2008 | 04:59 PM
thorax's Avatar
cool intresting read. yea mine are ce 28n but i belive there are diffrent offsetted front ones
Old Jan 1, 2008 | 05:00 PM
thorax's Avatar
your right i mean't 255/40
akuzus2k
Jan 12, 2018 10:02 AM
EELPIE
Sep 12, 2015 06:02 PM
SRR
Apr 13, 2008 12:30 PM
ronscolesdang
Jul 20, 2007 08:28 PM
onani
Dec 2, 2005 02:26 PM
