Crazy wheel setups...
Old Mar 21, 2008 | 11:07 AM
bullitt5897's Avatar
Default Crazy wheel setups...
Ok,
As some of you have read a few of my threads you should know I am looking for something unique!!! I have found the wheels and I know about what size I want to run. However, Everytime I ask the question of low offsets I get the typical it wont fit from those who have never tried.
What I am asking is: with a 18 x 10 what is the lowest offset anyone has run on a stock body? how much camber and what tire size?
What about with pulled and rolled fenders?
These are the rims I will be getting:
another similar sized lip I am going for:
The offsets I was looking at are: 18 x 9 +49 and 18 x 10 +37
Any nay sayers keep your mouths shut unless you can point out to me with the math why they won't fit. for example if it sticks out 2 inches from the body then I can understand that I dont have enough camber or I need wide fenders.
TIA
Mike
Old Mar 21, 2008 | 11:09 AM
the rim colors will be the blue in the first picture. If you have a wild setup with a crazy offset post up your pictures and specs such as offset, size and camber.
Old Mar 21, 2008 | 03:17 PM
AP2's Avatar
AP2
225/40 tire up front with a rolled and flared front fender and a 245/35 tire in the rear with a nice flat roll and -4 camber and you should clear those.
Old Mar 21, 2008 | 03:20 PM
silentdancer's Avatar
its a tough squeeze but it will work if you are going for that look
Old Mar 21, 2008 | 03:36 PM
alleykat's Avatar
Personally I hate Volk offsets.But anyways I have a similar fit out in the back.Half an inch wider but offset is very close.So heres a pic to give you an idea of how your wheels will stick out..
Old Mar 22, 2008 | 06:44 AM
AlleyKat thats what 0 camber in that pic. And arent these Sinji's old VSKF wheels. I think he used what like -3.5 degrees of camber and it fit... right?
Old Mar 22, 2008 | 07:54 AM
BlueS2000Boy's Avatar
beautiful wheels by the way. I almost went with these painted gold and silver for my G37. but i ended up going with the GTM's in all gold...
Old Mar 22, 2008 | 03:06 PM
HonCBRf2's Avatar
Wow, that's just insane to have your tires like that...better watch out for those curbs.
Old Mar 22, 2008 | 06:39 PM
jimbrowski00's Avatar
Also, I recommend cutting the rear bumper mounting tab near the wheel well. Thats usually the part that actually rubs on most set ups and can give you the extra space you are probably going to need.
Riley might be of help here too so you might want to send him a pm. He's always been really good about answering questions I've thrown at him.
Nice wheels btw and props for trying something new.
Jim
Old Mar 22, 2008 | 06:49 PM
Sinji's Avatar
you can go as low as +32 in the rear for stock body with max camber(about 3.5 on stock camber bolts), fender rolled and relocated bumper tab. the fronts are okay with camber mods.
