Different tire makes front and rear
Old Feb 22, 2006 | 07:44 AM
gomarlins3's Avatar
Default Different tire makes front and rear
I am not sure if this should be in Wheel and Tires or Racing, but here goes. Can you run Hoosiers in front and Victo's in the rear or will that really screw up the handling at the track/ autoX?
Old Feb 22, 2006 | 08:19 AM
stitos2k's Avatar
Mixing and matching is never a good idea man.
Old Feb 22, 2006 | 08:34 AM
PilotKD's Avatar
Although not ideal, it's not like you're mixing and matching left and right side tires. Front and rear mixing and matching won't be too significant as long as you're going with similar tires. ie: two R-compounds. Again, not ideal and you'd definitely want to experiment slowly before you go all out on the track and end up losing it in a turn because of your tire setup.
gomarlins3's Avatar
That's what I thought, but I found a good deal on some front Hoosiers.
AZS2KDancer
Dec 7, 2017 01:17 PM
illestrolla
Dec 3, 2012 01:26 PM
Formula
Jun 13, 2005 06:34 AM
RainMan
Dec 23, 2004 11:56 AM
2kjunky
Dec 2, 2002 05:06 AM
