Different tires???
Is there any consequences of running a different tire on the front than what is on the rear? Also what is the widest width you can put on the front....will a 245/45/17 fit without rubbing? Thanks
There is no way the 245/45R17 will fit on your car in the front and doesn't even fit the car correctly in the rear. It is .8" taller than the OE size. The biggest I would recommend would be 225/45R17 with possible a 235/40R17 in the front.
Jim
Jim
