Dumb lugnut question
Just wanting to double/triple check but will these lugnuts fit on some Enkei PF01's? I guess are lugnuts universal? Was gonna go ahead and order these. Thanks
http://www.andysautosport.com/honda/...i23479054.html
Those lugs *should* work fine. Practically all aftermarket wheels including the PF01s have 60 degree conical seats for lug nuts, you might want to confirm that those lugs are NOT for OEM wheels which have spherical seats.
I guess my posts regarding PF01 in the other thread were useful to you after all!
http://www.racinglab.com/muteki-c-tn-or.html
Description:
12mm X 1.50RH
For most Acura, Honda, Toyota, Mazda, Mitsubishi, Daihatsu
60 Degree angle taper for use with most aftermarket wheels
Does Not work with stock wheels
60 degree conical confirmed, they're fine.
Description:
12mm X 1.50RH
