ecsta mx...again
Old Apr 30, 2003 | 05:51 PM
s2kpdx01's Avatar
Default ecsta mx...again
so i went and checked out some of the specs on the oem S02 for the honda s2000 and the mx (225/50/16) on tire rack
S02: Section Width 9.2
MX : Section Width 9.3
S02: Measured Rim Width 7
MX : Measured Rim Width 7
so what am i missing?? why would i need a 245 in this tire in order to have just as wide of a contact patch as the S02??
It seems like it is just as wide (if not a tiny bit wider) then the OEM s02 as a 225!
Old May 1, 2003 | 01:48 PM
Jim@tirerack's Avatar
Former Sponsor
The tread width is what is different about the S02 not the section width. The S02 has a very square shoulder.
Jim
Old May 1, 2003 | 01:49 PM
s2kpdx01's Avatar
[QUOTE]Originally posted by Jim@tirerack
[B]The tread width is what is different about the S02 not the section width.
Old May 3, 2003 | 11:30 AM
svann's Avatar
I looked at the MX yesterday and found the section width to be about the same but the shoulder of the MX does roll more gradually resulting in a smaller tread width and contact patch. The amount of space between the tread blocks is also greater with the MX so I think there is a reduction in total contact area available. Unless the compound grips better than the S02 I cannot see how they could reach the same dry grip. I'm still torn between the OEM S02, MX and BFG KD for my stock wheels I use for Auto X and track only. The MX is certainly a good value but I wonder if it is as quick as my OEM's. The current Tire Rack comparisons show a close result between the KD and OEM S02 as far as ratings go but no test results (like the KD, MX, Pilot, AVS track test) between the two.
NYS2K
Sep 27, 2008 01:23 PM
wannabuy
Jul 30, 2005 06:14 AM
geezer
Feb 26, 2005 09:42 AM
Rusler Firbrand
Jan 12, 2004 09:00 AM
STL
Dec 14, 2000 06:01 AM
