Enkei PF01 fitment help / pic request
I'm looking at buying a set of Enkei PF01s, 17x7.5 w/ +45 in the front and 17x8.5 w/ +40 in the rear. I am at a stock ride height and will be running 215/40 tires in the front and 235/40 tires in the rear. Will I see any rubbing at a stock ride height? Also, does anyone happen to have pictures of these wheels on an S2K? Thanks guys.
Fitment is a little off...you want a little more offset rear than front. I would also recommend running 225/45 f and 245/40 rear, you shouldn't have any rubbing at stock height.
Either way, run 45s up front and 40s rear, to keep things level.
I local AZ guy had these and put pics up in the AZ section
here is his for sale thread ( sold the car )
https://www.s2ki.com/s2000/topic/804...#entry19337119
here is 18x8 and 18x9 both +45 offset
shots of 18x9 +45 on all four corners
