Enkei rpf1 17x9.5 +38
Originally Posted by s2k13
I'm riding on 17x9.5 with 245 front and 255 on back with buddyclub suspension and I had to roll my fenders in order for them to not rub. Once rolled you should be good.
I totaled my 300ZX Twin Turbo and just bought a 2001 Honda S2000. Before they sent my 300ZX to the salvage yard I took off my aftermarket Enkei wheels with Hankook tires on them and I want to ask if this setup will fit on my 01 S2K with out modifying the car...
Enkei RPF1: FRONTS: 17x8 offset: 35mm -- w/ Hankook V12 tires: 235/45/17
Enkei RPF1: REARS: 17x9 offset: 35mm -- w/ Hankook V12 tires: 255/40/17
Here is a picture of mine, 17x9.5 +38 with 255s x4:
I'll be honest...this setup isn't exactly for the faint of heart. You'll definitely have to do some massaging of your fenders, and A LOT of work up front. As previously mentioned, you can get 95% of the look just going 9j +45 all around, and just putting a 5mm spacer in the rear.
Originally Posted by Joemndz' timestamp='1375907732' post='22712295
Originally Posted by RedCelica
Do you have your fenders rolled and flared? Are you lowered? If you're going non stagger, I'd say 255s all around would do the trick, but that'll require a decent bit of fender work.
This was one of my previous wheel/tire setups.
