Falken Azenis Rt615s on AP2 wheels (pic request)
Hello I just bought my s2k few days ago and I am new here,
I have recently noticed that they dont offer the azenis in our stock wheel specification.
I assume I will have to go 225/50/17 in the front and 255/40/17 in the rear? Could someone clarify which tires will be closest to the stock specs?
Also does anyone have some pictures of these tires? will my wheel gap be affected? Will it affect my fenders? Let me know, thank you.
-brian
-brian
I had these on my stock AP2 rims and they are a perfect fit being dropped on Eibach springs. Alot of people on the board is running that setup also. 225 and 255. The same tires on my TE37 rims I am slightly rubbing in the rears.
to the op:
for the front, 225/45/17 is fine. if your concerned with any type of rubbing or want to remain close to stock stagger ratio, you can try 215/45/17. 255/45/17 is perfect for the rear.
Originally Posted by 22calbr,Nov 20 2006, 04:57 PM
reason i ask is because i am getting major rubbing on the front fender liners with any aggressive cornering. thanks
I didn't roll any of my fenders yet but I will soon if I am still rubbing after my alignment. I only rub in the rears from what I can tell. My alignment specs are below....
Front Rear
Camber -.7 Camber -2.0
Caster +6.5 Toe 1/4
Toe 1/16
Front Rear
Caster +6.5 Toe 1/4
Toe 1/16
I've got 215/45 and 255/40 615's on mine...I'll try to remember to snap a pic tonight. It doesn't look much diff from stock imo. A bit less room in the wheel wells, but if I didn't tell someone they wouldn't notice it.
Mark
Mark
http://www.vulcantire.com/azenis_rt615_t.htm
I am seeing 215/45/17 and 245/45/17 in the stock configuration.
is that right??
is that right??
