A first ever for an S2000!
I think you should lower the rear more so you start tucking the tire. Lowering also has the effect of pulling the wheel in a bit. Then add more camber, 3.5 to 4 degrees should do it.
The stance now looks a bit off but it looks like you should be able to pull it off.
Props for taking the risk in the first place
Glad they worked out and you showed all the peaple on the previous page with the negative comments. Thye shoulda waited until you had them mounted to post.
Just my opinion, I'd keep the stance right where its at.
