Fitting Bbs rs
Old Jun 12, 2014 | 06:43 AM
16vnick's Avatar
Default Fitting Bbs rs
So I just picked up a set of 5x114.3 Bbs rs the center bore size I believe is 68mm where as the s2000 has a 70.3 has anyone mounted the same set up of wheels and how did you get around the smaller centre bore of the wheels being that it's only a 2.3mm difference
Old Jun 12, 2014 | 08:21 AM
Manga_Spawn's Avatar
Site Moderator
You can usually run a small 5mm spacer to deal with the hub issue. You could also get the wheels bored out but that is more difficult.
Old Jun 12, 2014 | 08:55 AM
16vnick's Avatar
With a 5 mill would I need longer wheel studs or am I still safe
Old Jun 12, 2014 | 01:19 PM
Site Moderator
5mm is the max spacer you can run without longer studs.
MrClean
Jan 7, 2012 10:41 AM
api36
16
Aug 31, 2010 03:45 PM
richjsy
Nov 25, 2009 04:32 AM
J's_Suzuka
Aug 5, 2007 09:00 PM
JerryX
Feb 26, 2007 06:03 AM
