g35 rims on an s2k?
Old May 10, 2006 | 07:43 AM
LT_s2k's Avatar
Default g35 rims on an s2k?
i was wonderin if the 19" g35 rims were ever put on an s2k by anybody on the forum...or do u kno if it will even fit???
Old May 10, 2006 | 07:45 AM
S2KBDub's Avatar
They're basically the same as the Work Emotion rims that I do know fit on the S2000. Doubt the G 35 rims fit on the S2000.
Old May 10, 2006 | 08:25 AM
MULDER's Avatar
No.. bolt pattern doesn't match.
Old May 10, 2006 | 09:08 AM
CIVICTOS2000's Avatar
Sorry Mulder but the Bolt pattern is the same... 5 lug 4-1/2" ...the center hole diameter might be diifferent I don't know but it has to match to be hubcentric...
D.
Old May 10, 2006 | 09:17 AM
iqbal624's Avatar
right, the bolt pattern matches but the offset also may not work. they are 18*8 and 18*8.5 both +30et.
Old May 10, 2006 | 09:26 AM
MULDER's Avatar
D.
[pimp slap D.]
Ok... rims and tires aren't my strong suit. I asked this question years ago and it was explained to me but I don't exactly remember. The short answer is no.
If they did, do you think this guy is the first to ever have the thought? No... and have you ever in your life seen an S2000 with G35 rims on it? No. So, going off that.. one must draw the conclusion that...
Old May 10, 2006 | 09:38 AM
Project22a's Avatar
They won't work. Too low of an offset; they'll stick out beyond the fender.
Old May 10, 2006 | 09:40 AM
SIIK2NR's Avatar
No....no.....and HELL NO!!!!
Old May 10, 2006 | 09:56 AM
mic_crispy's Avatar
haha a better question is whyyyyy??
Old May 10, 2006 | 05:56 PM
iam7head's Avatar
if the offset is low, it should SUNK in, why you said it will stick out?
?? Did i missed something here?
