Good idear or Bad idear
Originally Posted by AP2,Jul 31 2006, 09:17 AM
the goodyear F1 is very comparable to the S03s that come on the s2k...as for playing around get some Kumho Ecsta 411 and use them only when you want to do some side shows...
As posted SEVERAL times above the OE tire is the S02. The S03 is an alternative aftermarket tire. It is not as good as the S02, but it is cheaper and will last longer.
The '04+ cars came with a Brigestone RE050. The REO50 is not as sticky as the S02, but the OE sizes are wider than the OE S02s. The RE050 will wear longer than the S02.
At 16,000mi your S02s do NOT have ample tread on them, they are shot. I guarantee it. You need to look at the INSIDE edge of the tire, not the outside edge. Negative camber will wear the insides.
Running with worn tires is a receipe for disaster.
Drifiting is an invitation to crashing into a curb or a light pole. Also, your differential is not designed for drifting and WILL prematurely fail.
You can drive it like an asshat, but don't be surprised when you break it, and it costs a LOT of money to repair it.
Originally Posted by VAD,Jul 31 2006, 11:40 AM
What the hell is an "idear"?
OCC ^haha
OK thanks for clearing somethings up guys.
I just took a look at the inside edge on my tires and they look perfect. I bought this from a old man so I doubt he was drifting...BTW wasnt this car made to drift? Or was it just made with an amazing suspension for cornering?
Just picked this up 2 weeks ago so im still learning here. NO WORRIES THOUGH, I dont spin it in bad situations. AND I always have my camera on me
The key is to swap the tires side to side to even out the wear every 5k or so.
when you say swap...you mean take the tire off the rim and have it mounted on the other side right? cant just swap directional tires?...or are they directional? damn i gotta go look
im thinking nissans R34 or mabye the supra?
