gouges on inside of wheel
Old Feb 19, 2006 | 01:28 PM
ShangTsung's Avatar
Default gouges on inside of wheel
When I go get my tires changed they internal clamp to get the tire off then external clamp with protectors to put the tire on. But the internal clamping leaves marks on the wheel.
Two questions:
1) Is internal clamping the only way to dismount a tire?
2) Does internal clamping always result in gouges on the wheel?
internal clamping:
external clamping:
Old Feb 19, 2006 | 06:11 PM
Race Miata's Avatar
A proper machine should have rubber feet on the "clamps" to NOT leave gouges. The most you should get are black footprints from the rubber that can be rubbed off.
Old Feb 19, 2006 | 07:40 PM
spider2k's Avatar
Active Streak: 30 Days
you can use the "external clamp" method to take the wheels off. how the hell else would you dismount a reverse mount wheel
s2kdriver80
Jul 2, 2018 10:52 AM
akimel
Nov 5, 2009 07:36 PM
MikeyC
Sep 29, 2006 11:36 AM
PilotSH
Jul 17, 2006 01:17 PM
Schatten
May 9, 2002 04:31 PM
