gramlite fitment
Old Mar 29, 2011 | 04:40 PM
diaz8645's Avatar
Default gramlite fitment
Alright. Let me sr if u guys can help me. Ive got somebody trying to sell me a set of gramlites 57c wrapped in dunlop star spec 245 45 17 with a 32 offset. Will this wheel and tire fit with factory suspension setup for now
Old Mar 30, 2011 | 10:26 AM
Dcon67's Avatar
No, a 32 offset is very agressive and will require fender work even at stock height.
Old Mar 30, 2011 | 02:51 PM
diaz8645's Avatar
Okay thank you
Old Mar 30, 2011 | 07:51 PM
Mar48's Avatar
what are the wheel widths? It will fit on factory suspension because pretty much everything fits on stock suspension.. If you wanna go lower you will most likely need camber + a roll to make it fit... But this all depends on how wide the wheels are
Old Mar 31, 2011 | 07:31 AM
rohde88's Avatar
considering he's running 245, I'm guessing its at least an 8" probably 9" wheel. If he ran a 225, 235 it would help, but not eliminate his problems.
Old Mar 31, 2011 | 10:42 AM
Mar48's Avatar
Yep I figured at least 8" but there is a big difference between 8 and 9, although I'm not sure what problem you are talking about? They will fit without extensive fender mods as long as they are 9" or less. And they will fit without anything at stock height, but will most likely stick out again depending on width
The guyver
May 17, 2014 02:24 PM
diaz8645
Mar 29, 2011 02:33 PM
sho-one
Sep 15, 2008 08:31 PM
Fubawu
Jan 24, 2007 07:29 PM
sperry
Dec 30, 2001 01:25 PM
