Has anybody ran 315/35/17 tires?
#21
Site Moderator
I would have to look for wheels with this specs. Or you can google it since it's for your car. I know I have come across options before. As mentioned look at forged star.
http://www.forgestar.com/v2/wheelscf5.php
#22
I have not seen anyone here with a s2000 ona forge star 18x11+ wheel. I don't want to be the first.
I know for a fact there are a few guys here with enkie nt03 in 18x9.5 +40 widen to 18x11 running 295/30/18. So far this seem like the best option got high power street driver s2000 with out over fenders.
#23
There's only so much a wider tire actually can do, and generally it's more to do with lateral grip than drive grip. And more to do with contact patch *shape* than area (which isn't directly affected by width).
On the street, at this power and weight, going to 315s isn't going to save the op from wheelspin, aside from the additional rotational inertia acting to reduce it a small amount.
I do drive a car with similar power and weight, on the street, strip, and track, on street and track tires, so some experience in this precise realm...
I appreciate the contribution and effort you put into your responses typically, but at the end of the day that doesn't always make them accurate.
#24
Sorry for being a dick, edited post above to remove things said in haste not really meant...
I'd just like to add that I think that for maximum grip tire make/model is far more important than size.
For OP's usage (street, autoX, ?), extreme perf category tires would seem to be the place to be. Very limited selection for tires wider than 255 in 17" sizes, so 18" makes sense. That said, selection of 295/30-18 tires is limited (AD08/AD08R, ???). Better selection in 275/35-18. It would be interesting to compare 295/30-18 AD08R vs. 275/35-18 ZII for resistance to wheelspin on the street. I wouldn't want to try to predict a "winner". In either case, I still predict wheelspin in 1st gear.
If tire life and wet-weather usage aren't considerations, you *might* consider going to semi-streetable R-comps. I'm going with Nitto NT01 on the FD next year for driving to/at/from the track (255/40-17, 275/40-17). In R-comps there are a lot of options in 275/40-17 and 275/35-18, but wider than that, again somewhat limited. Toyo R888 is available in 295/30-18, though....
#25
Site Moderator
#26
Originally Posted by s2000Junky' timestamp='1387594223' post='22932858
ZDan, your clearly over analyzing this for the sake argument,
To bring up a few of your arbitrary points- The OP is looking to mount a 295 or 315 on a proper width rim ie; 11-11.5" so your comments on shape/pinch/profile weren't necessary, If he wanted to go with a 9-10" rim I would likely feel the need to bring up the compromises. Thats how you like to run your set up isn't it- too big a tire for the width rim?) Factoring in the weight of the car and power compared to other cars with similar specs, again wasn't necessary.
I really don't have the need nor desire to get into a counter point battle in a thread with you, though I'm well capable of doing so. First step is to call out the BS portion, which is 75% of your argumentative point. The rest I would discuss.
#27
#28
#29
the taller gearing of the vehicles help put the power to the ground so if you wanted to change your final drive, that would help too. you can look at viper's to get an idea as they have monster torque out of their 8.0? v10's. another thing is sidewall due to added flex. moving up from a 275/40/18 to a 285/30/18 advan neova, i can no longer full-throttle 2nd gear due to spinning (the 275/40/18 allowed me to not lose any traction winding out 2nd) so keep that in mind when moving to 18's. i plan to run 295 rears when my current rears run out and see how much room i have after that. 18's definitely have a wider range of tire choices. i say go forgestars! they're local to us too
