Help with 17x9 +44
Old May 27, 2007 | 06:31 PM
TAAXED's Avatar
Default Help with 17x9 +44
Hey guys,
Just put on some Volk Group-AV rims, pretty old school but they are 17x8 +45 and 17x +44 at the back, I just put on 235/40/17 at the front which is fine, running 1.5 deg neg camber and then at the back 255/40/17 with 2.5 neg camber...
Car is not lowered but it rubs when cornering hard!
What else would I need to do to stop the rubbing? I haven't rolled the guards yet but would you normally run more neg camber with wheels this size?
Any help would be much appreciated!
Old May 27, 2007 | 09:01 PM
jimbrowski00's Avatar
The guys who are running this setup successfully are usually running a narrower tire... like a 245/40/17 or even a 235/40/17.
What are you rubbing on? Is it the inside of the fenderwell or the rear bumper attachment point?
Jim
Old May 29, 2007 | 07:12 PM
TAAXED's Avatar
I think it's the inside of the fenderwell...
Does anyone have any wheel alignment specs for this kind of wheel setup?
Old May 29, 2007 | 09:04 PM
asnkasper's Avatar
you may need to have your rear fenders rolled. The rubbing noise from inside the fender well could also be the rear bumper bracket (its a metal tab). It may need to be cut and the screw may need to be moved back a few inches
Old May 30, 2007 | 11:23 AM
Jim@tirerack's Avatar
Former Sponsor
I would first recommend a 245/40R17 on the rear and then with that offset and width I would roll the fender lips.
Old May 31, 2007 | 06:29 PM
BSeriouS's Avatar
255 is too big for the 9 +44.
Run a 245 + camber and your set. Also, roll your fender tooo.
toniotran
Aug 25, 2012 10:58 AM
S2Kitt
Aug 4, 2009 01:21 PM
S2johnyK
Oct 5, 2008 06:48 AM
707S2K
Jun 18, 2008 10:02 AM
s2000alex
Jan 16, 2007 08:43 PM
