Help me decide
Old Oct 19, 2015 | 04:22 PM
Scylla's Avatar
Default Help me decide
im on stock ap1 rims and tires sizes right now. i want to upgrade to better/wider tires. i really like the advan rz and pretty decided i was going with a staggered set up 17x8 front and 17x9 rear both +45 offset on 225/255s. advan just came out with the rz ii in +63. now i cannot decide if i want to run them with a 255 square setup. the car will mostly be street driven but 2-4 autocross and 1-2 track days a year. i don't really want to buy two sets of rims. i've read so many threads of staggered vs non staggered and still cannot decide. i am going to roll the fenders and getting ohlins dfv. so about an inch lowered. i haven't seen any threads about 255 squared setup on the street. what would suit my needs more?
Old Oct 20, 2015 | 04:52 AM
RedCelica's Avatar
square > staggered. Will never go back. The ability to rotate is nice, just get a larger front bar. I'm running +62 wheels and with a 255 tire and lowered 2" I needed to only roll my fender tabs and didn't have to touch the fender itself front or rear. It's so much grip
Old Oct 21, 2015 | 09:02 AM
Manga_Spawn's Avatar
Site Moderator
It is safe to say nearly everyone with 17x9 +45 rpf1's drives their car on the street as well as the track. It is very common. I currently run a 17x9 +43 in front and the only real difference in normal street driving is the steering is a bit heavier. If you have an AP1 you can either get a larger front bar or smaller rear one (like an Ap2 oem rear sway bar). That will even out the suspension since they ap1 is more biased to oversteer and adding more tire in front compounds that.
Old Oct 21, 2015 | 06:35 PM
Scylla's Avatar
thanks guys. i've going with 17x9 +45 advan rz's with 255 re71r's. i will roll the fenders, relocate the tab, and trim fender liners. most people say to run -2 or -2.5 camber to get them to fit nicely. will i need anything to get that amount of negative camber or will i be able to get it being dropped about an inch? ill go with the moddiction sway bar and see how i like it. if there is too much over steer ill get the miata bar in the rear.
Old Oct 22, 2015 | 07:57 AM
Site Moderator
You don't need anything to get that camber from the OEM adjustment.
Old Oct 22, 2015 | 10:49 AM
RedCelica's Avatar
I maxed my front camber at -2.4
Old Oct 22, 2015 | 12:30 PM
Site Moderator
^How much you can get depends on ride height. I have -2.5 in front and -3.4 in the rear.
Old Oct 22, 2015 | 09:42 PM
s2000Junky's Avatar
Caster amount has an influence on your static camber adjustment throw as well I do believe. I'm maxed camber at -2.5 with 13" fender to hub ride height (essentially 1 finger gap) and 6.8 caster. The rear is the opposite, im maxed positive to get the same -2.5 camber. So there is far more negative camber influence in the rear vs front.
macdaddies911
Feb 11, 2012 09:04 PM
DaveZuck
Dec 7, 2011 04:28 PM
nartnailuj
Nov 29, 2011 01:03 PM
Rev9K27
Aug 8, 2011 04:45 PM
vtec88
Mar 5, 2010 04:46 PM
