help with my set up
Ok i have an 06 with SSR GT3 wheels 18 inch 8.0 +49 in the front and 9.5 +55 in the back. Im going to run a eibach pro kit springs which will give me a 1 inch drop. Then im going to run the T1R big brake kit which requires 55 mm from the rotor to the wheel. Im going to run a H and R 15 mm spacer in the front so my wheels will clear the caliper. What size tires should i run? Is this going to be too much? Am i going to rub? Appreciate it.
