Help needed quick
Old Dec 7, 2009 | 02:49 PM
eg_10_'s Avatar
Default Help needed quick
I have a set of 225-60-16 winter tires, studded.
Will they fit on my ap1 ? (on the stock wheels)
guy at the garage says it wont (maybe he's right , but he seemed to say that so he could sell me the tires)
Its gonna snow hard on wednesday, 20cm, would like to install tomorow.
Thank you very much
Ps : i tried the search but didnt findanything.
Old Dec 7, 2009 | 02:57 PM
Boostedtaco's Avatar
stock height? i have a feeling they are too tall.....
Old Dec 7, 2009 | 03:02 PM
eg_10_'s Avatar
stock height !
yeah thats what i'm scared of
i calculation almost 2'' bigger diameter in front :S
Old Dec 7, 2009 | 05:30 PM
eg_10_'s Avatar
Wheels: Wheel 1 Wheel 2
Wheel size 16x7.5 ET 45 16x7.5 ET 45
BackSpace 153 mm (6'') 153 mm (6'')
Tires: Tire 1 Tire 2
Tire size 225/50-16 225/60-16
Section width 225 mm (8.9'') 225 mm (8.9'')
Sidewall 113 mm (4.4'') 135 mm (5.3'')
Tire diameter 632 mm (24.9'') 676 mm (26.6'')
44 mm (7%) taller.
Rim sizes 16x6.5 to 16x8.5 16x6 to 16x8.5
Circumference 1984 mm (78.1'') 2123 mm (83.6'')
Revs per mile 811 758.2
Speedometer Assuming that this is OEM tire and speedometer readings are correct When speedometer reads 60mph (96.6km/h) actual speed will be 64.2mph (103.4km/h): 7% faster.
Clearance: Package 1 Package 2
Suspension Assuming that this is OEM wheel/tire and there is no any problems with clearance on both sides The same.
Fenders The same.
Wheelwells Will fill out the wheelwell by extra 22 mm. Make sure that you have enough room under the fender. If not, consider lower profiles or smaller rims.
Old Dec 8, 2009 | 06:02 AM
eg_10_'s Avatar
no one ????
johnfrey_s2k
Jun 15, 2016 12:25 PM
2tirefire
Jun 9, 2007 10:35 AM
shittles
Dec 10, 2006 04:27 AM
S2KB00ST
Jul 20, 2006 12:31 PM
MarionRioS2K
Mar 24, 2005 08:29 PM
