Help - uneven tread wear...what does this mean?
My LF tire is extremely worn in the inside part of the tread. I didn't notice this until after I had turned the wheels sharply when I parked yesterday. Is this alignment? Can I turn the tire around? Any help is appreciated.
jd
jd
actually, you can try getting an alignment but this car will have excessive inner tire wear if the car isn't driven hard in the twisties. If you drive in the twisties and give the suspension some flex, then you'll get a more even wear. if you dont... just expect a bit of wear. you gotta keep in mind, this is a sports car and you will see wear in aspects like this one, more so than a family sedan.
I agree that this wear pattern might be a consequence of proper alignment in a sports car, but would be good to check the alignment if not done recently or not at all.
I have 2.5 neg camber in the back and the A032Rs wore evenly at and near the shoulders with most of the wear in the center of the tire. Maybe a tad too much pressure, but the car handles well.
Scot
Sep 2, 2004 07:17 PM
