How aggresive is this? Too much?
Old Nov 9, 2009 | 07:49 PM
swifbboy's Avatar
Default How aggresive is this? Too much?
So I'm looking at maybe buying these wheels, but I don't know how much work it would would take to make these work; if at all. Anyone else running this setup/offset? I think the rears will fit with some work. It's the front that I am really worried about. Any info, help, or pics would be great! I don't want to buy these wheels only to find out they are going to be more trouble than they are worth.
Fronts:18x9 +31 Rears: 18x10 +68
thanks!
Old Nov 9, 2009 | 08:38 PM
rioyellows2k's Avatar
The fronts will need to be rolled or pulled, rears are OK at stock height. Roll the rears and some camber if you're lowered. You'll probably get better answers if you tell 'em what tire you're gonna run.
Old Nov 9, 2009 | 08:42 PM
1nate7's Avatar
The rear won't be a problem, might not even need a roll depending on your setup, but that will take a lot of work to make the front fit. You'll need a roll, probably a slight pull/flare, stretched tires, and a decent amount of negative camber.
Why are the fronts so much more aggressive? I think it will look strange with a very aggressive front wheel and fairly conservative rear. If you are going all out, might as well run a spacer in the rear to match the aggressive front fit.
Old Nov 10, 2009 | 12:17 PM
Jim@tirerack's Avatar
Former Sponsor
I agree. The front is going to take a lot of work.
Old Nov 10, 2009 | 12:44 PM
Dreaming_S2k's Avatar
thanks!
I am almost certain that on the fronts you'd probably need to pull the fenders almost flat out unless you stretched the hell out of some 225s on it. Even then...that's a fairly low offset for a 9.
The rears shouldn't be too bad...if you're lowered a good bit I could see you needing to relocate tab and roll. Probably wouldn't really have to pull back there though.
Old Nov 12, 2009 | 07:21 AM
swifbboy's Avatar
thanks all for your input. i guess i was pretty much spot on. but on the bright side of things, i have opted to go with some 17" work emotions instead. pretty excited.
pjf1985
Dec 15, 2013 10:41 AM
dsthez
Apr 23, 2013 12:06 PM
myclue
Oct 3, 2010 07:07 PM
Mister Jew
Apr 27, 2010 09:02 AM
wheresbao
Jun 15, 2006 12:14 PM
