How Aggressive Can I Go?
Old Feb 25, 2011 | 01:14 PM
  #41
GizmoPhoto's Avatar
im thinking: 205.40 and 215.40
Old Feb 25, 2011 | 01:46 PM
  #42
clarkster009's Avatar
Originally Posted by 1nate7,Feb 25 2011, 06:30 AM
That's because those tire sizes are so ridiculous that they don't even exist. A 185/35/17 is 2.5" shorter diameter than stock! Regardless of tire width, you need to make sure you at least keep the diameter close to stock. Bottom line, if you want any kind of stretch and run a reasonable tire size then you need to step up your wheel width, at least 8"/9". Minimum tire size I would run is 215/45/17 front and 245/40/17 rear. For a stretch, you will need at least 8.5" wheel front and 9.5" rear. I suppose you could run 205/45 and 225/40 if you don't mind sacrificing handling, at least the diameter is close.
This got me I can't believe people want to do this to an S2000...make it handle far worse than stock...just
Old Feb 25, 2011 | 02:17 PM
  #43
Mar48's Avatar
go here:
http://www.miata.net/garage/tirecalc.html
You need to keep the diameters of the tires close to stock.
40 series is still too small. You will need 45
Old Feb 25, 2011 | 02:19 PM
  #44
Mar48's Avatar
50 series is the closest
Old Feb 25, 2011 | 03:40 PM
  #45
GizmoPhoto's Avatar
tnx again mar
burglrdrift
Feb 22, 2012 04:47 AM
screwballz
Apr 27, 2010 12:06 PM
Hamburglar
Oct 29, 2008 04:40 PM
JimmyB
Aug 4, 2007 11:40 AM
tp-ap1
May 8, 2006 10:51 AM
