How to help oversteer with tires
Old Jan 19, 2006 | 12:02 PM
mikegarrison's Avatar
Originally Posted by rikhemi,Jan 19 2006, 12:49 PM
Will 255's be to big of a difference for the s2k.
It all depends on you and your needs. Also, you have to check and see if there are any 255s with the right tire circumference. And you have to consider that the 245/45 size is already pushing the limits on the width of the rear wheels -- 255s are probably too big for the stock wheels.
Really, before you dial in even more understeer, you really ought to take the advice of going to a car control school.
Old Jan 19, 2006 | 12:09 PM
spa-zz's Avatar
Originally Posted by david1,Jan 19 2006, 02:59 PM
The UK specs will not reduce tire wear. It will increase it.
Read my post again. That's what I said.
Originally Posted by spa-zz,Jan 19 2006, 02:10 PM
...better idea to run wider tires in the rear than use the ridiculous amount of toe-in in the rear....
Old Jan 19, 2006 | 12:25 PM
David1's Avatar
My bad, I read it to fast.
deepbluejh
Jan 30, 2013 02:40 PM
silvermonster
Jun 30, 2009 01:06 PM
xs2kFanaticx
Feb 10, 2008 01:54 PM
supertech
Nov 24, 2005 10:01 PM
mecracer
Jul 7, 2005 04:54 PM
