I need a lesson
Old Sep 13, 2007 | 10:28 AM
xxlap1xx's Avatar
Default I need a lesson
Im a noob to tires, plz give me a lesson of what stagger is??
For example stagger 1.5" 2"...... what are those??
Thanks for the help guys
Lub1
Old Sep 13, 2007 | 10:41 AM
bullitt5897's Avatar
stagger is the differences between the tire widths from front to rear. i.e. if your rims are 7.5 in. in the front and 9 in. in the rear you have a stagger of 1.5 in.
hope this helps
mike
Old Sep 13, 2007 | 01:16 PM
xxlap1xx's Avatar
thanks for da help
Old Sep 13, 2007 | 05:38 PM
Synchro's Avatar
More specifically, 1.5", 1", 2" etc. is referring to the width of the tread, not necessarily the width of the whole tire.
Stickies at the top may help explain why. Quick example is the OEM RE050 front tire, which is a 215/45R17 - 215mm is the width of the tire, but it only has about 6.7" of tread width. Most 215mm wide tires have more than 7" of tread width (usually closer to 7.5").
Hope that helps a bit.
CenturionS2K
Aug 14, 2010 10:37 AM
siadam
Jul 10, 2008 11:57 AM
JMH
Apr 1, 2007 08:51 PM
batikan
Nov 29, 2005 06:06 PM
iceple
Mar 11, 2003 12:43 PM
