Installation Question
Old Jan 15, 2013 | 08:57 AM
s200000's Avatar
The ability to run a certain size spacer (with the amount of stud remaining in mind) also involves the offset of the wheel, correct? And I'm not sure, it's pretty damn close as it is which scares me.
Old Jan 15, 2013 | 09:11 AM
Jim@tirerack's Avatar
Former Sponsor
If you are using a centering ring and a spacer you would be better off with a spacer that is piloted to match the hub and the wheel. I would also suggest longer hardware and get around 6 full turns of engagement on the hardware.
Old Jan 15, 2013 | 04:25 PM
s200000's Avatar
The thing is I really don't wanna go through the process of changing wheel studs. Would it be possible to bore out the openings in the wheels .03"s so I can run ET lug nuts? Has this been done?
Old Jan 16, 2013 | 03:27 PM
s200000's Avatar
Does anyone have any insight into my last question?
Old Jan 17, 2013 | 09:52 AM
chViETnk's Avatar
i would invest in a torque wrench. should be at about 80lbs
i often see that lug nuts are over torqued by hand.
diaz8645
Nov 8, 2011 05:04 PM
fishs2000
Feb 18, 2010 04:24 PM
HYPEBEAST!
Jul 2, 2008 12:23 PM
J_STATUS
Jun 16, 2008 11:36 AM
designfreak
Jan 8, 2007 03:51 PM
