Wheel spacer on OEM (whats the max mm?)
Old Jun 16, 2008 | 08:14 AM
J_STATUS's Avatar
Default Wheel spacer on OEM (whats the max mm?)
i just bought new wheels and the offset for the front is +48 i want to put a spacer atleast 5mm but i want to know if you can put wheel spacer on stock wheels studs.
and will it be safe with less tread turns?
Old Jun 16, 2008 | 09:06 AM
1nate7's Avatar
You will lose over 3 full turns of the lug nuts with 5mm spacers. Personally, I wouldn't risk it. You can get extended wheels studs, but it's not an easy process to change them out.
Old Jun 16, 2008 | 11:36 AM
Jim@tirerack's Avatar
Former Sponsor
You need to get longer lugs. You also need to check on how much center bore you have left and make sure the wheels are still going to be hub centric.
johnckeen
Jun 11, 2018 04:44 AM
supersteezy
Jun 8, 2013 01:00 PM
TheKleinschmidt
Jul 16, 2012 11:06 AM
Fiducial.
Apr 15, 2010 06:40 AM
WindchaserS2K
Aug 8, 2006 07:33 AM
