interested in advans wondering if they will fit
Old Aug 15, 2010 | 11:24 PM
R00567's Avatar
Post interested in advans wondering if they will fit
im looking into getting these advan wheel + tire combo for my ap1.
my ap1 is on stock suspension + stock height. my fenders are stock and not rolled in the front or the rear.
the wheels are Advan RS's in 18x8.5 with a set of RE-01R's. i think the offset the guy said was 40 offset.
BOLT PATTERN is 5x114.3
my question is are 18's too big for a s2000 or will they work ok? i have no problem in being raised like a rally car if it is functional and i dont have any rubbing issues.
the setup is not staggard so the front matches the reach size wise.
the tires that come on the wheels are 235/40-18.
i can change the tire sizes when i get the wheels to something more S friendly. i was just wondering if the wheels themselves will be ok to fit on my car.
any help is appreciated. thanks again for looking...
and here is a pic of the wheels
and here is a pic of my S
Old Aug 16, 2010 | 12:09 AM
HRS2000's Avatar
Do you now if the holes for the wheelnuts are right ? And if the centre holes in the wheels are the right size ? Centre holes have different sizes front and rear .
The rear I think will fit . But the front will give problems with a +40 and 18x8,5 and a 235 .
Old Aug 16, 2010 | 01:29 AM
R00567's Avatar
what do you think i should ask the seller? they are coming off of a subaru sti.
should i investigate what the bolt pattern is? and im ready to get different tires in the front if i have to...
Old Aug 16, 2010 | 02:24 AM
R00567's Avatar
Bolt Pattern is 5x114.3
Old Aug 16, 2010 | 09:20 AM
HRS2000's Avatar
S2000 frontaxle bolt pattern 5x114,3 center bore 64.1
S2000 rearaxle " " 5x114,3 center bore 70.2
You also have to check the center bore . The S2K has a different center bore front and rear . Normally the center bore for Subaru is around 56mm . And that's to small for the S .
Old Aug 16, 2010 | 11:33 AM
DRFlickner's Avatar
The centerbore will be 73.1 mm on the Advan RS wheels. You can use hub centric rings to center them on your hubs.
The RS was never offered in 18x8.5" +40 though. The wheels are either +31 or +50mm offset, as these are all that Advan offers.
235/40/18 is also too tall of a tire size for the S2000, which will probably create rubbing issues.
If the wheels have the +50mm offset, they should fit pretty well on your car if you change the tire size to something more suitable, such as 245/35/18 front and rear.
Let me know if you have any more questions. I can definitely help you out.
Old Aug 16, 2010 | 07:29 PM
R00567's Avatar
Cool
sweet man i really appreciate the heads up. im praying to god they are the 50 offset (since the stock sti is 53)
ill keep you posted man and once again thank you~!
sewelli
Jul 19, 2014 06:13 PM
spyderlink101
May 2, 2014 11:01 AM
SurS1004
Aug 21, 2012 01:24 PM
Bennett124
Mar 3, 2010 12:44 PM
Grendel
May 12, 2008 05:42 PM
