Issues? and Tire Rec.
Old Jun 26, 2009 | 04:37 AM
MurderS2K's Avatar
Default Issues? and Tire Rec.
Finally.....ive decided on a set of wheels for the time being. Due to limited selection....
I am going to go (F) 17x7.5 +48offset & 17x8.5 +45offset
Old Jun 26, 2009 | 09:52 AM
JP Money's Avatar
You should be ok if you are not slammed. For tires I'd say stock tires specs for an AP2, which is 215/45 in the front and 245/40 in the rear.
Old Jun 26, 2009 | 10:10 AM
s2k dre's Avatar
The fronts will fit good, and the rear u can get away without a roll just with camber, thats only 20mm more than stock. Thats with 215/45 and 245/40
Old Jun 27, 2009 | 11:49 AM
Jim@tirerack's Avatar
Former Sponsor
I have sold the 215/45R17 and 245/40R17 alot with the size and offsets you list. If I can help with the tires let me know.
Old Jun 29, 2009 | 05:17 AM
MurderS2K's Avatar
i will defiently let you know and i guess i should have mentioned- i am going to be going slammed before i put the new rims/tires on.
BC N+ Spec
Old Jun 29, 2009 | 01:36 PM
Former Sponsor
When you lower the car just run more negative camber.
Old Jun 30, 2009 | 05:01 AM
MurderS2K's Avatar
and i presume by - getting a camber kit? If so, what kit would you recommend and what settings should i set it too?
Also, with this knowledge of the mods that will be installed - what tires specs do you rec for the rims (F) 17x7.5 and
stoopidchris23
Feb 22, 2011 06:28 AM
ntr_s2k
Jul 27, 2010 04:51 PM
Moddiction
Apr 24, 2009 09:49 AM
SpGish20
Oct 16, 2007 01:11 PM
Randman
Dec 2, 2002 02:40 PM
