Just another wheel fitment question
So I'm trying to get my wheel Fitment dialed in on my car. So here's where I need you Fitment gurus to come in! Currently I'm running 17x9+45. With 215/45 f and 225/45 r. I have my fenders rolled and ever so slightly pulled. I'm wanting to sit to where I'm tucking tire. So with that being said what more fender mods and/or how much camber should I run to achieve the look I want. Thanks in advance.
You have correct fitting wheels but you are running stretched tires. You know you could easily run 255's all the way around right? Anyways to answer your question about further ruining your car you shouldn't need to touch the fenders any more. Just slam and run something like 3.5-4 degrees of camber and enjoy the ruined ride.
Again if they are already rolled flat then you should be ok you just need more camber. 2.5-3 should do it. You could also run 245 all around for a little more clearance. In the rear there is no reason you couldn't already fit a 255 with those wheel specs.
B serious
Dec 12, 2013 10:35 AM
