Just triple checking before placing my order
Old Dec 2, 2012 | 07:38 PM
s2000Junky's Avatar
Originally Posted by RedCelica
I run 225/45 on a 7" wheel...it's fine
Sure its fine, but its not ideal. I'm sure you wished your front wheel was 8" for those meats instead right? If I were placing an order for brand new wheels tonight, id want them to be great with my chosen tires, not just "fine" Hella-yo!
Old Dec 3, 2012 | 12:21 AM
S2k007's Avatar
With an 8 inch width, a vertical side wall would actually be 235 tire.
With a 7 inch width, a vertical side wall would be 215 tire.
So 225 is fine as its just one size up which is what plenty of people do with the stock wheels.
http://www.tirerack.com/tires/tires....s+V12+evo+K110
Go under the specs tab.
Old Dec 13, 2012 | 04:22 PM
EGkid's Avatar
Ok so I ordered the rears at 17x9 +45 the fronts I'm debating on 17x7 +42 or 17x8.5 +35. I've come to the conclusion that I have to roll the fenders, what would you run? Ideally I wanted a 17x8 +45 but it's one extreme or the other.
Old Dec 13, 2012 | 05:07 PM
RedCelica's Avatar
why not just do 17x9 +45 all around?
Old Dec 13, 2012 | 05:21 PM
Dreaming_S2k's Avatar
This, and you could stagger your tires leaving the wheel size itself unstaggered. So in other words:
F: 17x9 +45 with 225/45/17
R: 17x9 +45 with 255/40/17
Old Dec 13, 2012 | 05:22 PM
s2000Junky's Avatar
Depends on the tire, many extreme performance tires we use run wide. If you want to know what the fitment is going to be sometimes you just have to put them on, but looking up the manufacture spec sheet on dimensions gives you a good idea.
Old Dec 13, 2012 | 05:24 PM
s2000Junky's Avatar
I agree with this, given the OP rather crumby alternative wheel size options.
Old Dec 13, 2012 | 07:58 PM
EGkid's Avatar
I'm not a fan of stretched tires at all. Turns out the wheels are on backorder for 4-6 weeks I'll see if I can decide on another set if not I'll wait for these.
jWESTFOO
May 17, 2014 07:03 AM
Mallain123
May 15, 2013 09:45 AM
adidas_man
Jan 30, 2011 02:45 AM
Trent06
Oct 27, 2010 02:03 PM
GpWaP1 s2k
Apr 7, 2010 02:04 PM
