losing air
Old Feb 7, 2005 | 07:21 PM
BLOWNJROCK's Avatar
Default losing air
i ordered tires mounted them friday and its been losing air. i mean it was almost flat this morning, then i aired it up and it went down 10 psi. what is the matter with this.
Old Feb 7, 2005 | 07:59 PM
01SilverS2k's Avatar
The same thing happened to me awhile back ago. I had brand new tires and I thought some nail punctured it. Luckily it was just a loose tire valve. So, I would check the tire valve first and see if there's a leak there. Place some water on it and if its bubbling then that's the culprit. Then go to an automotive store and get a tire valve tool for less than $5 bucks so you can tighten the valve core.
Good luck.
Old Feb 7, 2005 | 08:06 PM
BLOWNJROCK's Avatar
so you think its a valve leak?
thanks for the info!
Old Feb 7, 2005 | 08:09 PM
I would pray that it's just a leak at the valve if I were you... Otherwise that might be more than a $5 fix...
Old Feb 7, 2005 | 08:21 PM
BLOWNJROCK's Avatar
i hope so
Old Feb 10, 2005 | 07:52 PM
So did you get lucky? Or was it a puncture?
Old Feb 10, 2005 | 07:53 PM
BLOWNJROCK's Avatar
i aired it up, and it never lost air since then, i don't know what happened
markforrester99
Jul 11, 2017 12:46 AM
GavinSSAP1
Mar 22, 2011 03:00 PM
miamirice
Jul 6, 2010 02:10 PM
xxlap1xx
Aug 9, 2008 03:23 AM
sodaking663rd
Aug 27, 2007 07:55 AM
