Lugnuts
Old May 10, 2005 | 10:27 PM
jdnissanz's Avatar
Thumbs up Lugnuts
When I bought aftermarket 18" wheels with a 48 offset what type of lugnuts can I get any special sites with good prices and anyone know the exact sizes?? Or can I or should I use the stock lugnuts from the stock rims on my S2000...BTW anyone know where black lugnuts for aftermarket wheels could be purchased???
Old May 11, 2005 | 06:14 AM
deepee's Avatar
evasivemotorsports.com
depending on which rims you have, you can fit stock lugs...there are other alternatives with keys/locks such as muteki, kyokugen (sp?), gorilla etc etc.
Old May 11, 2005 | 07:43 AM
03_AP1's Avatar
many aftermarket rims require tapered conical lug nuts, and the stock acorn nuts won't work.
Old May 11, 2005 | 09:54 PM
jdnissanz's Avatar
Hey guyz another quick question which kind of lugnuts can I get can I get the closed ended lugnuts or are the open ended the way to go?? I am ordering form evassive sooo I need to know soon thanks in advance!
Old May 11, 2005 | 10:05 PM
MaxGeek's Avatar
You can get closed ended lugs. I would recommend McGard Tuner Lugs and McGard locks. You can get theem from amazon.com. The powder coat is much nicer then those of muteki, its shiner and thicker. Of course they cost more though.
Old May 12, 2005 | 07:39 AM
rijowysock's Avatar
oem= acorn (conical)
aftermarket are tapered
which means dont use ur oem nuts they have rounded end. aftermarket wheels have a 60degree taper so they have more surface area on the wheel.
anywho.. open ended/closed dont matter it just depends what u like. i prefer closed because they dont cause any errosion on the studs... esp if u live up north open ended rnt good to have in snow/salt etc
Danwolski
Apr 22, 2012 01:59 PM
AP1_S2k
Sep 26, 2007 07:11 PM
AndyThomason
Jan 23, 2007 08:44 AM
DannyCoolBeans
Jan 10, 2007 05:36 PM
460cidpower
Mar 20, 2006 02:53 PM
