MF10 rubbing
Hi all,
I got MF10s (bronze), but it seems on hard cornering i get rubbing. I'm running 225 front, 255 back, on Advan AD07.
Is this suppose to happen? I thought the MF10s should fit without rubbing? Any suggestion as to how to reduce rubbing (already running 2.5 degree camber rear, 1 degree front).
Thanks in advance.
Thanks in advance.
Are you rubbing in the front or the rear? Under cornering, going over bumps or both?
You could do several things to fix: Up your spring rate, increase the diameter of your sway bar(s), increase compression dampening or roll your fenders.
RedHonda703
Dec 27, 2003 08:24 PM
