wheel size help
hello, anyone know if 18x8 +45 for the front and 18x9 +45 for the rear fit without any problems. and if it will fit, what size of tires do i need for the front and rear. thanks a lot
it will fit, however you have to run some camber and roll the rear fender especially if the car is lowered. you can run 225 and 255 respectably but most would recommend 245 for the rear. run at least 2.5 in the rear and 1.5 for the front camber and you should be fine.
to be on the safe side if you are planning on lowering without rolling the front fenders i recommend a 215
