Motegi Tracklites
Old Sep 25, 2006 | 05:27 AM
wazzurp's Avatar
Default Motegi Tracklites
Hey I had a quick question for you guys. What would be the best combo for front and rear wheels. I was looking at putting a 17x9 245x45x17 in the rear, and a 17x7 with a 205x50x17 in the front let me know if there is a better combo.. I am looking at getting the motegi tracklites. Thanks
Old Sep 25, 2006 | 09:21 AM
Jim@tirerack's Avatar
Former Sponsor
I only show a 17X8 ET45 wheel available. To have a chance of making this work it would have to be with 215/45R17 front and 225/45R17 rear tires. It would still be tight with the 45mm offset. I have the wheel in stock at 288.00 per wheel.
If I can help let me know.
Old Sep 25, 2006 | 09:43 AM
l8brakr's Avatar
Jim, the fronts are where he'd really need to worry with 17x8. The rears with that fitment and the euro alignment should be fine to go for the 245/40 tire. This is of course using the wheel specs you shared not the make believe sizes the OP asked about. Motegi also makes a 17x7 ET42 that would be fine on the front.
Old Sep 25, 2006 | 09:48 AM
wazzurp's Avatar
Yeah, I want to kep the 205 in the front because I think the car would push on the 225 in the fronts. If I go 17x8 in the rear I should be able to go with the 245x45 right? With the front I could go 205x50 with the 17x7? I could possibly go 215 in the front to but I definitely want the wider wheel in the back and the not so wide wheel in the front..Thanks for the help, any suggestions on light tires that still hold up. I know about the Porxes T1rs any good?
Old Sep 25, 2006 | 09:53 AM
Former Sponsor
The 205/50R17 is not going to fit the 17X8 wheel. That is why I would go 215/45R17.
Old Sep 25, 2006 | 10:06 AM
Conedodger's Avatar
Think you got your terms mixed up. More grip up front will induce oversteer. Push is understeer.
Old Sep 25, 2006 | 11:03 AM
wazzurp's Avatar
Ohhh about the understeer and oversteer thing. Jim, I could put the 17x7 on the front and then put the 17x8 on the rear couldn't I. I would like to know the best combo for tire and wheel size. Anybody who autocrosses your help is appreciated.
Thanks
Steve
xbcyl
Jan 26, 2011 01:07 AM
whitemike1644
Nov 28, 2008 12:32 PM
joes2
Apr 10, 2006 05:03 AM
Scorpion
Feb 10, 2006 08:48 PM
frans2k
Sep 20, 2004 08:17 AM
