my DD wheel/tire/spacer setup
ok so as a spirited driving and track tire I have ap2v3's with 225 255 re-11 but they are NOT cheap to replace almost once a year!
I grabbed an all rear AP1 setup and I have 225 tires all around on them not the s02's (I know narrower) but I just have some affordable tires on them that I can rotate and just enjoy cruising the s2000 when I don't need all that grip!
I will need spacers to run an all rear setup, 10mm in the front but the issue with that is there isn't enough stud IMO to TQ the wheel on properly.I found some 15mm 64.1mm bore spacers but Im unsure if the small little divots in the AP1 wheels will clear the bolts on the spacers. (I don't want to do extended studs just a pain)
I'll also be adding a 5mm spacer to the back just to even out the front and the rear.
mickfluff
Feb 15, 2003 10:37 AM
