Need advice
Old Aug 28, 2005 | 09:12 PM
LUV2REV's Avatar
Default Need advice
Curious to know what would be a better setup. I am looking at a set of 17" wheels that are available in 7 or 8 inch for the front with a 48mm offset. The rear is a 9" with a 63mm offset. Will the 8" work up front without rubbing or should I stick with the 7" ?
Old Aug 29, 2005 | 07:50 AM
NotoriousGQ's Avatar
8" up front would work depends on the offset.
Old Aug 29, 2005 | 08:11 AM
aggie's Avatar
If you intend to use 225 tires, 8" would be better. With 215's, 7" is adequate and there will be zero chance or rubbing.
Old Aug 29, 2005 | 10:43 AM
Jim@tirerack's Avatar
Former Sponsor
I have seen the 17X8 ET48 with the 225/45R17. It is tight but they do work. WIth the 17X9 you would be in a 255/40R17 rear. The wider tires in the front do work the best.
If I can help let me know.
Old Aug 29, 2005 | 04:53 PM
LUV2REV's Avatar
Thanks Jim. It is the Shuk WR1's I am interested in. I do not want to spend a fortune on wheels and these are reasonably priced and look to be of decent quality. My biggest concern is the front's rubbing with the 8 inchers. I am also planning on installing a set of Eibach springs which may aggrevate things more. Not sure what to do as the 7's are almost too small to run with the 9 inch rears and the 8 inch may rub.
run115
Sep 16, 2008 02:33 PM
IIGQ4U
Mar 31, 2006 07:01 AM
bzyrice
May 25, 2005 05:21 AM
johns2000
Feb 5, 2005 08:51 AM
klui_188
Nov 14, 2004 04:08 AM
