Need advice ?
Hello!
I want to buy wheels 18 inches in size 8J, ET50. Will I have a problem because I want to change the suspension.
What tires should I put in order not to rely.
Thanks for the reply!
I am not sure I would just run 18X8 all the way around. The 18X8 with a 50mm offset may need some fender lip roll or negative camber. The tire size would be a 225/40R18.
If I can help just let me know.
I put on wheels and no problem. Now I wonder what tires to put front and rear.
For the front I stopped at 225/40 and 245/35 for the rear
Do you think there will be a problem with these tires, if the car has lowering springs
Thanks!
Thanks!
