What tires size should I get?
Old May 27, 2012 | 10:48 PM
QZY's Avatar
QZY
Default What tires size should I get?
I have ordered 17*8 Front and 18*8.5 Rear wheels. And I will lower my ap1 to 2.0" with SKUNK2 LOWERING DROP SPRINGS. What tires size should I get? How about Bridgestone RE760?
Thanks
Old May 28, 2012 | 05:31 AM
takeshi's Avatar
What about them? What are you expecting from the tires? What are your priorities? What's your budget? If you want feedback then you need to clarify your needs/wants.
Old May 28, 2012 | 07:19 AM
1nate7's Avatar
The logical tire choice to keep factory tire diameter and stagger with a little increased width is 225/45/17 front and 255/35/18 rear. If you are running aggressive offsets and need a little more fender clearance, you could also do 215/45, 245/35.
Old Jun 3, 2012 | 01:27 PM
QZY's Avatar
QZY
I have a new problem on my wheels. The front wheels are not available on wheelsnext. Can I set them up?
Front: 18*8.5 5-114.3 +32
Rear: 18*9.5 5-114.3 +20
Old Jun 3, 2012 | 02:01 PM
1nate7's Avatar
Would need a fender pull and a lot of negative camber. I'd be looking for offsets at least in the 40's with those widths.
Old Jun 3, 2012 | 02:02 PM
S2k007's Avatar
Are you kidding? Those offsets are way too low.
Old Jun 3, 2012 | 05:36 PM
QZY's Avatar
QZY
I want to this style.
Old Jun 3, 2012 | 05:41 PM
1nate7's Avatar
Well, in that case you need to run a 215 or 225 max and it won't look like that just lowered on springs.
Old Jun 3, 2012 | 05:52 PM
QZY's Avatar
QZY
http://www.ebay.com/itm/2-New-18X9-5...sories&vxp=mtr
http://cgi.ebay.com/ws/eBayISAPI.dll...m=260896899745
So I need to buy these wheels and springs?
And what size of tires should I need?
Old Jun 3, 2012 | 06:45 PM
S2k007's Avatar
Why do you want that "style"? That looks horrible and will make your car perform worst.
