Need a consensus
Old May 22, 2013 | 06:57 PM
lolS2K's Avatar
Default Need a consensus
So I need new tires and decided to go ahead and make the jump to 17" wheels while I'm at it. I've got a Berlina Black AP1 and after searching for the past couple weeks, I've decided on Motegi MR122's in gold. Now the dilemma: Some websites (tire rack included), say these won't fit. Other websites, like this one, say they will fit.
It's a 17x8 5x4.5 with an offset of +48. By all I can figure, these should fit. But why are some websites saying other wise? I'm planning to run a square set up since my S is a daily driver.
Picture for reference:
Old May 22, 2013 | 07:46 PM
Manga_Spawn's Avatar
Site Moderator
They should fit as long as the hub bore is t to small. It is worth mentioning that you will still be narrower than oem ap2 rears. Do they not make a 9 inch wide one so you can run a staggered setup?
You will need to roll your front fenders. Rears might be ok but you might get them done to be safe.
Old May 22, 2013 | 08:04 PM
s2000Junky's Avatar
Shouldn't need to roll anything with that fitment, unless he is dropped low or/and going to run some meats up front. If just the OEM 215/245 sizes are being used I wouldn't be concerned. But always nice to do to run more rubber in the future, or change ride height if decided.
Old May 22, 2013 | 09:06 PM
Site Moderator
Enh the fronts could still be an issue. Maybe if he isn't lowered he will be ok but if he is definitely the fronts.
Old May 23, 2013 | 04:05 AM
lolS2K's Avatar
Stock ride height, but I plan to roll the front fenders anyway. Mainly because I plan on putting 225's up front. Going to run 245's out back. The hub bore is 72.60, which I believe is larger than the OEM? Don't really remember to be honest though
Old May 23, 2013 | 08:22 AM
S~Factor's Avatar
The wheel should fit just fine.
If you need the hub rings for them, shoot me a PM, I have one extra set.
Stock bore sizes:
70.3 Fronts (need 2.3mm ring)
64.1 Rears (need 8.5mm ring)
Old May 24, 2013 | 03:53 AM
dc2-2-ap1's Avatar
The link you posted does not list the s2000 (unless I missed it). 17x8 +48 will fit without any fender mods. I would not recommend them though. 8" is to narrow in the rear. If you do run them, I would recommend running 215/45 in the front- a 225 will fit, but a 215/45 has the same rotational diameter as a 245/40. If you run 225/245, your front tire's sidewall will be larger than the rear.
Old May 24, 2013 | 04:59 AM
lolS2K's Avatar
How is an 8" too narrow? That's .5" wider than the stock size.
And here's a picture of the sidewall comparisons. They're ALMOST identical:
I could run a 245/45 out back if the sidewall is really that big of a concern:
Old May 24, 2013 | 05:46 AM
dc2-2-ap1's Avatar
It's not a huge difference- it is 1/3". I am a stickler for equal rotational diameter, or a larger diameter in the rear. Realistically it won't make that much of a difference, and most would just say I am just being anal.
8" is better than ap1 width, but ap1 widths suck lol. This is how I see it, a 245/40 has a fairly large sidewall, most tires have weak sidewalks to begin with, and ballooning a 245 on a 8" wheel will put unwanted stress on an already weak sidewall. I would take ballooning over stretching any day though.
Take my opinion as just that- an opinion. That setup isn't optimal, but it is still better than the stock ap1 setup. I prefer 8.5 or 9 for rear widths.
Old May 24, 2013 | 05:50 AM
lolS2K's Avatar
I'm pickin up what you're throwin down now. Thanks for the input
toolowap1
Jan 9, 2014 01:25 PM
Flawless_S2K
Mar 25, 2012 02:22 PM
nightcrawler7188
Apr 27, 2009 09:26 AM
ChristianElizaga
Feb 23, 2009 05:46 PM
Tommi1980
Mar 15, 2007 06:04 AM
