Need help...17 inch wheels and tires
Old Jan 18, 2003 | 08:12 AM
OPTION's Avatar
Default Need help...17 inch wheels and tires
Will the following set up be ok to use?
- Front 17x7.5 with 205/50/17 tires...avail in 43 and 48 offset...which offset to choose?
- Rear 17x7.5 with 225/45/17 tires...avail in 43 and 48 offset
TIA
Old Jan 19, 2003 | 03:12 PM
OPTION's Avatar
15 views, no replies? Can anybody please help?
Old Jan 19, 2003 | 03:14 PM
lig's Avatar
lig
In my opinion, you will make the car handle worse with a setup like that.
Old Jan 20, 2003 | 07:27 AM
Jim@tirerack's Avatar
Former Sponsor
The 48mm offset would be the way to go. Both tires will fit on the 17X7.5 wheel. The 48mm is a little low for the rear but you have a fairly narrow wheel and tire so you should be OK.
Jim
Old Jan 20, 2003 | 10:07 AM
Unicron's Avatar
OPTION,
Just my opinion...but don't go any less than 245/40/17 in rear!
This means you will need a 17x8.5 wheel bud...+55mm at least.
cangta
Mar 28, 2012 02:40 PM
newchapter
Jul 13, 2011 02:25 PM
shukriya
Nov 29, 2004 01:31 AM
frans2k
Sep 20, 2004 08:17 AM
