asa AR1 45mm offset. RUB?
Old Mar 27, 2012 | 02:42 PM
cangta's Avatar
Default asa AR1 45mm offset. RUB?
looking at a set of asa AR1 17" they have a 45mm off set. will the stock tires rub?
Old Mar 27, 2012 | 04:41 PM
Mark355's Avatar
Wheel width? Ride height?
Old Mar 27, 2012 | 04:50 PM
cangta's Avatar
oops sorry. stock height, 17x8. 245/17/40
Old Mar 28, 2012 | 07:06 AM
Reckon's Avatar
No. I have stock suspension and have 17x7 +48 up front on 215/45 17 and 17x8 +45 in the rear on 245/40 17. No issues what so ever. Used the fitment guide and double checked with Jim at Tire Rack to make sure.
For the front:
Offsets lower than +43 are not recommended on the front because a very narrow tire would need to be used to avoid rubbing.
+43 to +47 offset: 205 tires, 6.5" - 7.5" wide wheel
+48 to +52 offset: 215 tires, 7.0" - 8.0" wide wheel
+53 to +57 offset: 225 tires, 7.0" - 8.0" wide wheel
+58 to +62 offset: 235 tires, 7.5" - 8.5" wide wheel
+63 or higher offset: 245 tires, 7.5" - 8.5" wide wheel
For the rear:
Offsets below 40 are not recommended for the rear because a tire narrower than the stock tire would need to be used to avoid rubbing.
+40 to +44 offset: 235 tires, 7.5" - 8.5" wide wheel
+45 to +49 offset: 245 tires, 7.5" - 9.0" wide wheel
+50 to +54 offset: 255 tires, 8.0" - 9.5" wide wheel
+55 to +59 offset: 265 tires, 8.5" - 9.5" wide wheel
+60 to +64 offset: 275 tires, 9.0" - 10.0" wide wheel
+65 or higher offset: 285 tires, 9.0" - 10.0" wide wheel
Old Mar 28, 2012 | 01:56 PM
Boost76's Avatar
You till need to run 195/50 tires all around & -3 camber all around to make it fit PLUS roll your fenders & relocate tabs.
Old Mar 28, 2012 | 02:40 PM
S2k007's Avatar
Really hope this wasnt a serious post
jimmy11
Dec 5, 2012 02:29 AM
suzawadc2
Jun 23, 2011 12:25 PM
gre165-makis
Συμπεριφορά
Sep 13, 2010 10:22 PM
dmw16
Oct 4, 2006 06:23 AM
OPTION
Jan 20, 2003 10:07 AM
