Need help with alignment square setup 315s
Old Jun 8, 2012 | 05:21 PM
  #21
arazs2k's Avatar
Old Jun 8, 2012 | 05:25 PM
  #22
Mark355's Avatar
315s on a 9? wtf.
Old Jun 8, 2012 | 07:01 PM
  #23
RedCelica's Avatar
Wow...seeing those tires on those wheels and all I can think about is Thanksgiving.
Old Jun 9, 2012 | 02:06 AM
  #24
ZDan's Avatar
Optimal alignment depends on many factors, but generally you won't want much toe at all (zero front, maybe 0.1-0.2degrees total rear?) as wider tires generate more lateral force per slip angle, and you shouldn't need as much camber as narrower tires (might try ~1.5 - 2 degrees all around? WAG...) Then again, way-too-wide tires spooned on to narrow (for 315 tires anyway!) wheels might suggest a bit more camber than that. I dunno...
Tires are definitely WIDE for 9" wheels! Nitto gives 10.5" - 12.5" as the rim width range for your tire size. Your wheels are 1.5" narrower than the minimum!
Old Jun 9, 2012 | 09:40 AM
  #25
arazs2k's Avatar
Thanks for the help some one answered my question finally.
I know 9" is a bit small but i havent had any problems.
Old Jun 9, 2012 | 12:11 PM
  #26
clarkster009's Avatar
Why get such a low offset if you want to run 315s? With that wide body you could get wider wheels in a higher offset.
Old Jun 9, 2012 | 12:57 PM
  #27
RedCelica's Avatar
Here's a thought...buy bigger wheels!
No problems? Have you taken a corner yet?
Old Jun 9, 2012 | 01:17 PM
  #28
arazs2k's Avatar
Previous setup i was running 265 all around i never thought i can run 315s on the wheels i have right now but i guess i was wrong .I ordered a tire to see the fitment and as u can see the results .............. , low offset makes it more aggressive .
flush on 9" wheel with +17 offset works for me.
Old Jun 9, 2012 | 01:30 PM
  #29
arazs2k's Avatar
Originally Posted by RedCelica
Originally Posted by arazs2k' timestamp='1339263630' post='21768483
[quote name='ZDan' timestamp='1339236417' post='21767912']
[/quote]
Yes day n night difference from running the 265s
Now i take big U turns in second gear full throttle with 4.77 gears not even a squeak.
Im going to track soon will see how it performes.
Old Jun 9, 2012 | 08:00 PM
  #30
RedCelica's Avatar
what tires did you have before?
