Need help with offset and fitment ?
Old Feb 16, 2011 | 12:25 AM
shivic's Avatar
Default Need help with offset and fitment ?
i want to put some wheels on my girls s2k.
the car will not be lowered. i can get a great deal on as set of
Rays Gramlights 57F 17x8.5 +40 5x114 all the way around. 245/45/17
are these going to look retarded. if you were going to throw a tire on these, what would you suggest. i was thinking 225/45/17 all the way around, so that i can rotate them and stuff. keep in mind, stock heigth, girl driving, never racing or hard cornering.
Old Feb 16, 2011 | 04:46 AM
RedCelica's Avatar
is there any stagger on the tires?
Old Feb 16, 2011 | 05:30 AM
Dreaming_S2k's Avatar
They would not look retarded at all. It may look just a tad aggressive in the front, but overall that's a very good, functional setup. You may not have to roll the fenders at all if you're not lowered, but I am not 100% on that.
Old Feb 16, 2011 | 05:39 AM
Jim@tirerack's Avatar
Former Sponsor
I would say a fender lip roll will be needed. Make sure they have the correct center bore as well. Your car has a larger center bore on the front than the rear.
Old Feb 16, 2011 | 07:47 AM
shivic's Avatar
no stagger. the set of wheels are all the same. should i have skinner front tires to make it look ok
Old Feb 16, 2011 | 07:48 AM
shivic's Avatar
what does a larger center bore on the front refer to.
Old Feb 16, 2011 | 07:49 AM
shivic's Avatar
so if it has an aggressive look, does that mean its going to stick out on the front and flick rocks up off the paint?
Old Feb 16, 2011 | 12:12 PM
RedCelica's Avatar
what size are the tires?
Old Feb 17, 2011 | 02:23 PM
shivic's Avatar
245/45/17 is the size of tire.
Old Feb 17, 2011 | 04:21 PM
1nate7's Avatar
The wheels are fine, the tires will look semi-retarded because they are oversized diameter. I don't know how aggressive she is but you are probably better off with staggered for less oversteer. I'd run OEM AP2 sizes, 215/45 and 245/40. A 245/45 will definitely cause problems in the front even at stock height.
