Need help from SPOON experts!
Old Oct 29, 2008 | 03:22 PM
DougEFresh's Avatar
Default Need help from SPOON experts!
Are spoon wheels anodized? I'm thinking they are because it's lighter than paint or powdercoating. Also i don't think Desmond ever offered the color except to Spoon Sports. I recently picked up a set that is showing some oxidation and i have a buddy who could re-anodize them for me. your thoughts???
-Doug
Old Oct 29, 2008 | 03:29 PM
trunger's Avatar
you should spray rust gard on it or just flat black paint
Old Oct 29, 2008 | 03:33 PM
DougEFresh's Avatar
I think someone on this board would shoot me if i took i can of spray paint to a set of spoon wheels, on plus side the anodizing is free.
Old Oct 29, 2008 | 06:11 PM
WyattH's Avatar
actually... wtf is anodizing exactly?
Old Oct 29, 2008 | 07:19 PM
DougEFresh's Avatar
Anodizing, or anodising, is an electrolytic passivation process used to increase the thickness of the natural oxide layer on the surface of metal parts. Anodizing increases corrosion resistance and wear resistance, and provides better adhesion for paint primers and glues than bare metal. Anodic films can also be used for a number of cosmetic effects, either with thick porous coatings that can absorb dyes or with thin transparent coatings that add interference effects to reflected light. Anodizing is also used to prevent galling of threaded components and to make dielectric films for electrolytic capacitors. Anodic films are most commonly applied to protect aluminium alloys, although processes also exist for titanium, zinc, magnesium, and niobium. This process is not a useful treatment for iron or carbon steel because these metals exfoliate when oxidized; i.e. the iron oxide (also known as rust) flakes off, constantly exposing the underlying metal to corrosion. "Stay-Brite" is sometimes used as a market name for products made from anodised aluminium such as brass replica.
Anodization changes the microscopic texture of the surface and can change the crystal structure of the metal near the surface. Coatings are often porous, even when thick, so a sealing process is often needed to achieve corrosion resistance. The process is called "anodizing" because the part to be treated forms the anode electrode of an electrical circuit. Anodized aluminium surfaces, for example, are harder than aluminium but have low to moderate wear resistance that can be improved with increasing thickness or by applying suitable sealing substances. Anodic films are generally much stronger and more adherent than most types of paint and metal plating, making them less likely to crack and peel.
thanks wikipedia.
Old Oct 29, 2008 | 07:46 PM
DougEFresh's Avatar
found my answer. Yes they are anodized.
Owen_1987
Feb 13, 2010 03:26 AM
slicknick
Oct 8, 2006 01:18 AM
Ro_Ja Boy
Jun 27, 2005 11:25 PM
