need help on wheel and tire set up.
Old Feb 10, 2012 | 10:36 AM
aznvietboy725's Avatar
Default need help on wheel and tire set up.
So I'm the spring, i am planning on buying new wheels, coils, tires, brakes, rotors, and lugs. We I have in mind right now is these te37 reps called Varrstoen. The smallest size they offer is 17x9 + 30. I was planning on buying 17x9 + 30 for fronts, and 17x9.5 + 30 rears. The coils (bilstein pss or pss9) will hopefully give me a one inch drop and I have a body shop that will roll all fenders and relocate rear tab.
My question is to you folks is:
will it fit and if not how will I get it to fit? Camber adjuments? Tire sizes? (I would like to avoid a high negative camber and stretching i tires.)
I'm fairly new to the car scene so im not familiar with car terms. So please explain as detailed as possible.
THANKS YOU!
Old Feb 10, 2012 | 11:05 AM
ftpsk8's Avatar
You will have to stretch some tire, and you will have to run some (maybe not that high) negative camber. No way around even with a roll and pull. Someone else will chime in with some better info as regards to tire sizes and what not.
Old Feb 13, 2012 | 01:02 PM
I'm fine with little stretch and some negative as long as I can drive it as a daily car in the spring and summer ill be fine.
official_s2k
Jan 26, 2014 09:58 AM
aznvietboy725
Jan 31, 2012 07:13 AM
buzz944
Jul 6, 2009 10:33 PM
Andrewap1
Feb 19, 2009 07:56 PM
swaps2000
Jan 23, 2009 10:53 AM
