Need to know ASAP ! S200 HUB BORE SIZES!
Old Jun 10, 2010 | 03:33 PM
MY00S2000's Avatar
Default Need to know ASAP ! S200 HUB BORE SIZES!
Hi there, what sizes do i need to get my wheels machined to fit the s2000 hub bore size? ive seen
70 70.1 70.3 70.7
what is the official sizes?
Old Jun 10, 2010 | 07:15 PM
1nate7's Avatar
I *think* it is 70.1. It's no big deal if you go slightly bigger, you can always run a hubcentric ring.
Old Jun 11, 2010 | 03:14 PM
Jim@tirerack's Avatar
Former Sponsor
The front is 70.3 and the rear is 64.
Old Jun 11, 2010 | 05:25 PM
Mister Jew's Avatar
If the bore of the wheels are bigger does that matter?
Old Jun 11, 2010 | 06:58 PM
MY00S2000's Avatar
Ok so this is for whoever searchers this same question and reads this thread
- I am 100000000% certain it is 70.1 MM
I had them machined today and it fits perfect.
yes- bigger affects the load bearing capacity of the rim as well as the stability of it ( vibrations etc )
this is why hubcentric rings exist to make the rim run concentric to the hub. The closer to the hub size it is the better the rim will peform
so the offficial word is 70.1 MM
Old Jun 12, 2010 | 08:36 AM
Mister Jew's Avatar
i just ordered a set of wheels that use a 73mm bore. i was gonna order hub centric rings. i did some research and found out my rpf1s are 73mm as well im not running any rings and the car is fine with no virbrations. so i guess ill be okay
Old Jun 12, 2010 | 08:43 AM
ans2k's Avatar
Hum let's see, Jim said 70.3 and some random guy said it is 70.1.
Old Jun 12, 2010 | 11:53 AM
Former Sponsor
The 70.3 is what you need to be able to put the wheel on the car.
Old Jan 6, 2011 | 11:07 AM
macr88's Avatar
Bump
Old Jun 3, 2013 | 03:27 PM
joshf47's Avatar
Looking at rims that have a 73.1 centre bore
will these work?
