Need opinion on lowering with CE28
Old Jan 5, 2014 | 01:37 PM
sunk318's Avatar
Default Need opinion on lowering with CE28
I recently got CE28 from a fellow member here.
Here are the specs of the rims:
18x7.5 +43
18x9.5 +40
If I lower 1" with Eibach springs, would I have to roll the fenders?
Thanks!
Old Jan 6, 2014 | 08:48 AM
sunk318's Avatar
Can anyone help? Thanks!
Old Jan 6, 2014 | 08:55 AM
Manga_Spawn's Avatar
Site Moderator
It will fit but you need to roll the front fenders because while it may not run when the wheel is straight when it is turned is can grab the fender. You will need at least 2.5 degrees of camber for the rear so you can run a 255. Front should be fine at 1.5 or even OEM whatever that is and a 215 or 225 is fine for the front fender.
Old Jan 6, 2014 | 11:29 AM
s2ka's Avatar
See page 1 of the Wheel Fitment Guide at the top of the page.
Old Jan 6, 2014 | 11:55 AM
sunk318's Avatar
By having 2.5 degrees of camber, do you mean negative degrees?
I read it before posting but does not answer the question I asked here.
Old Jan 6, 2014 | 12:10 PM
RedCelica's Avatar
You're gonna have to roll the rears
Old Jan 6, 2014 | 12:40 PM
Site Moderator
Yes of course negative camber.
He has rolled rear fenders.
Old Jan 6, 2014 | 12:46 PM
RedCelica's Avatar
Sorry should have qualified that statement with "possibly more"
OP, did the rear roll cup the "lip" tight against the fender or do you still have some of it poking inward? Like it's been said, you may have to end up with more camber than you'd like, or more effectively roll the rear.
Darbs242
Sep 28, 2016 07:38 AM
Uzi
May 6, 2015 08:33 AM
k24accord
Mar 9, 2011 01:00 PM
mrcbr600
May 8, 2010 08:37 AM
chhatre9
Dec 11, 2008 06:23 AM
