negative camber issue
Old Oct 14, 2004 | 09:01 AM
Costas's Avatar
Default negative camber issue
I just replaced my rear oem tires with oem tires again (bridgestone potenza s02 225/50/16) and i noticed that i now have negative camber in the rear. My car is bone stock with no mods whatsoever.. how weird is that
Should I go get an alignment?
Edit: Also I noticed that my old tires didn't have perfectly even tire wear, but when I would look at them from the back the camber seemed alright, now it's alot more noticeable.
Old Oct 14, 2004 | 09:32 AM
Fongu's Avatar
If I remember correctly, the factory spec. is -1 degrees negative camber on the rear wheels. The alignment can change from pot holes, going off road, loose adjustment nuts, etc. It's worthwhile to get the alignment as regular maitenence say every year or two. Easiest way to improve your handling.
Inside tire wear is normal, since fatory spec is for some negative camber. You'll notice more inner wear if you do a lot highway and don't do a lot of spirited cornering.
Old Oct 14, 2004 | 10:21 AM
Costas's Avatar
Yeah this is my daily driver and I drive 30 miles to school and 30 back every other day. I guess that explains it. thanks!
helpilot
Jan 5, 2013 05:38 PM
QuangNguyen_89616
Oct 17, 2012 08:23 AM
Aliminator
Jul 16, 2012 07:00 PM
kylemonster85
Apr 29, 2008 12:30 PM
gerryk
Oct 19, 2003 09:46 PM
